heat/AC controls
Old Dec 18, 2002 | 01:59 PM
harry's91rs's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
heat/AC controls
I hope I have the right board. It has to do with the fan for the vents in the car. Anyway, my fan in the car doesn't work when I turn it on the highest setting. It works on every other setting below high, but as soon as you turn it on high the fan just cuts out and doesn't blow any air through the vents. Every once in a while it will work, until I turn off the car and turn it back on then the problem is back. Anybody have a clue why it is doing this and how I can fix it?
Thanks,
Harry
Old Dec 19, 2002 | 08:03 PM
black85camaro's Avatar
Car: 85 Camaro
Engine: 350 Carbed
Transmission: Stock 700r4
test your blower relay. On high the electrictiy goes through the relay. On other settings they go through a set of resistors then to the blower motor. So test the relay and see if that is your problem.
Old Dec 20, 2002 | 04:09 AM
MdFormula350's Avatar
yeah i would start with the relay and work from their. that is weird how it works and then doesnt.
Old Dec 20, 2002 | 11:54 AM
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
I'm going to check the relay today. Sounds to me that the relay is bad. I'll keep you posted if the relay is the problem
Old Dec 20, 2002 | 02:52 PM
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
Well I replaced the relay, the one one the left side of the engine bay towards the back, and the problem was not fixed. Do I have the right relay? Its the one in the back on the left side of the engine bay. My Car is put away for the winter, but I would like to get this fixed now, when I have the time. Could it be a loose wire or a bad blower?
Thanks Harry
Old Dec 21, 2002 | 07:48 PM
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
I figured out the problem. Pep Boys sold me a bad relay, it doesn't click when you apply power to the two terminals. I used a relay from another car and it works fine. I ripped apart the controls inside to see if it was a bad switch, all for nothing. I'm going to try and take the relay back to Pep Boys.
Thanks for all your help,
Harry
tmellott89
Oct 14, 2015 02:06 PM
loud91rs
Oct 5, 2015 10:05 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
tattmann
Sep 27, 2015 05:20 PM
Damon
Sep 26, 2015 04:29 PM
