Tranny fluid temp
Old Dec 19, 2002 | 04:52 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
Tranny fluid temp
My 700R4 has a ~30000 GVW B&M transcooler on it, in front of the radiator behind one of the fog lights on my Iroc. I have a temperature sensor in the tranny pan, and I'm lucky if the fluid gets over 110 degrees F during the winter. Is there a negative effect to running my tranny so cool?
Old Dec 20, 2002 | 04:21 AM
MdFormula350's Avatar
recent new thread about the tranny temps.
Old Dec 20, 2002 | 06:07 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Good question and there are as always differing opinions. The stock trans cooler in the rad acts as a heat exchanger warming the fluid as the engine heats up. Most experts recommend using the stock cooler in the rad in conjuntion with the aux unit unless you live in a hot climate or subject the trans to hard or severe duty. Just like motor oil ATF is subject to changes in flow as temp rises or falls. I would be more concerned with how long it takes to get up to temp than the actual temp itself. Ever notice that a cold tran tends to shift a little firmer? Line pressure changes as the fluid heats up. If it concerns you I would have the system flushed completely with synthetic ATF. Syn ATF has better low temp flowability and will provide better performance over a larger temp range.
Old Dec 20, 2002 | 12:25 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Since I live in southern Arizona, it does get fairly hot here. After about a 2 hour drive through stop and go traffic, my tranny temp might get up to 150F during the winter. I don't have the stock cooler anymore since I have a Griffin radiator, so I suppose I'm stuck with a cool tranny regardless. My tranny has slipping problems in the first place, it just slips a little less when it's running cool.
Thanks for the info.
Old Dec 20, 2002 | 03:36 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
and I thought my grandfathers 2002 HD truck just had a jacked up gauge when it took it a long time to get 125* then a bunch of hot off roading to get to 150 ish
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
meeklay812
Oct 1, 2015 03:46 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
