warmer at freeway speeds
Old Jan 22, 2003 | 04:32 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
shouldnt it be the other way around?? (due to airflow) im cooler in stop and go traffic, and hotter on the freeway speeds.
yes, my airdam thing underneath is in place.
thanks
Old Jan 22, 2003 | 08:39 PM
MdFormula350's Avatar
if the air dam is good , mostl likely i would guess there's something physically blocking the radiator, or maybe your lower radiator hose is colapsing.
Old Jan 23, 2003 | 11:06 AM
Diggler86's Avatar
Car: 86 TA
hmmm, i cant imagine something blocking the radiator, but i'll check.
i just had the lower hose changed about a month or so ago. i believe this condition existed before that though. so the hose is new. didnt have the spring inside but it was from napa and pretty sturdy seemed.
Old Jan 23, 2003 | 08:23 PM
H0TR0Dn's Avatar
Car: 88 Formula 350
I had the same problem on my 79 TA. would run cool unless i raced anyone or kept the rpms at 2800 or above. I could drive 50 miles without a problem if i went the speed limit. It was that way for a while. Ended up being a bad surface job that a machine shop did. A friend of mine had that Hydro carbon test kit(not sure of the proper name). You put it on in place of the rad. cap and it changes colors if you have a leaking head gasket.
Old Jan 23, 2003 | 10:10 PM
BLUETA's Avatar
Car: 86 TRANSAM
Engine: 406
My 86 has a pretty short air dam, and it was rolling back at the bottom. I ran really hot at 45 mph. I bolted a slightly longer one over the original and it helped a lot. I used one off a S-10 pickup. Total cost for air dam from junk yard and bolts was $7. It even has bracing on the back side at the b ottom edge to make it stiffer. If all else fails, itwon't costmuchto try it.
Elephantismo
Feb 13, 2019 12:51 AM
Nighthawkf-117
Sep 24, 2015 02:47 PM
RedLeader289
Sep 23, 2015 06:50 AM
adelane
Sep 9, 2015 08:51 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
