Will I have heat?
Subscribe
Mar 4, 2003 | 03:29 AM
If I put a 160 degree thermostat in my 92 RS will my heater put out enough heat in the winter time? I have a 160 in my LS1 and I get great heat in the cold, but will my 92 RS with a 305 TBI be the same way? Thanks guys.
Reply 0
Mar 4, 2003 | 06:43 AM
Depends on how cold it gets and how long you want to wait to get warm. A 160 is too cold for proper engine operation first of all, but you can figure about 45-55 degrees below stat temp as far as duct air is concerned . A 170 or 180 might be a better choice.
Reply 0
Mar 6, 2003 | 12:28 PM
i recommend a 170 or 180
Reply 0
Mar 6, 2003 | 01:00 PM
i would run a 170 t-stat at lowest also!
Reply 0
Mar 6, 2003 | 06:24 PM
Why wouldnt you guys use a 160 degree thermostat? Ive heard that it can cause the computer to stay in open loop but i dont see how because the computer goes into closed loop long before it reaches 160 degrees.
Reply 0
Mar 6, 2003 | 09:56 PM
I have a 160 stat and the coldest it got down here this past winter was to like the high 30s, and I still had heat. I always let my car warm up about 2 or 3 minutes and it's enough time for it to go to closed loop.
Reply 0
Mar 7, 2003 | 06:37 AM
Quote:
You are right, the car will go into closed loop at around 105 deg coolant temp assuming the O2 sensor reaches temp. Problem is the ECM is programmed for a target temp and by running it that cold you will find if you place it in field service mode it will almost always run rich. With a carb it may not matter as much, with EFI operating parameters are a little more critical for overall driveability.
Reply 0
Mar 8, 2003 | 01:35 AM
gotcha, thanks for the info
Reply 0
Mar 17, 2003 | 06:16 AM
Temps in the 30-50 degree range, my 305 carb took a while to warm up with the 160* stat.
180 is a good median.
Reply 0
Apr 1, 2003 | 02:49 PM
ive always ran a 180, i live in seattle and ive never had any problems, always have had hot air after about 3 minutes, and never a overheating problem. i say go 180
Reply 0
Apr 1, 2003 | 11:03 PM
Thanks for the info everyone, HITHERE appreciate it.
Reply 0
Subscribe
