Only one fan coming on!
Old Mar 8, 2003 | 03:35 PM
KC10Chief's Avatar
I only have one cooling fan coming on in my engine. Any ideas why it might not be coming on? It's the passenger side fan that won't come on. Thanks! Matt
Old Mar 8, 2003 | 06:14 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
It could have a bad motor, relay, wiring, the list can go on for a long time. Check all the fuses first, thats really easy. Check for power at the motor. Try to tap the side of the motor when the car is running at operating temp. If it starts to run once tapped, change the motor. You situation will most likely be more complicated than this, but it gives you a few ideas to start with.
Old Mar 8, 2003 | 07:11 PM
breathment's Avatar
the fans come on at differen't temps.. the seconday fan cuts on at 238* i believe..
Old Mar 8, 2003 | 10:00 PM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
Also the pass. fan is controlled by a switch in the passengerside head
Old Mar 9, 2003 | 11:32 AM
KC10Chief's Avatar
Okay, when I put the paperclip thing in to do the diagnostics check, only the drivers side fan came on. They should both ome on right? Thanks! Matt
Old Mar 9, 2003 | 01:18 PM
breathment's Avatar
nope. only one fan turns on when u jump the ALDL A and B terminal. the secondary fan is not connected to the ECM
the 2nd fan comes on when the temp reaches 238* or when the A\C is turned on. (if u have A\C)
Old Mar 10, 2003 | 09:13 PM
MdFormula350's Avatar
here's a diagram that might help.
eightsixseven
Dec 16, 2024 01:50 PM
krisner89
Oct 10, 2015 06:03 AM
Papaginos
Sep 27, 2015 03:29 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
Leggman1
Aug 6, 2015 04:15 AM
