Problem with temp
Old Mar 18, 2003 | 05:04 PM
86FirebirdV8350's Avatar
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
Problem with temp
Ive noticed just recently that my car has been running hot...the temp up here right now is about 60* everyday and the temp fluctuates as I drive. It used to stay just a notch under 220* with my 195* t-stat but now gets as hot as 240*+ hardly redlines but will if I'm at a stop...as long as I keep the car in motion above 35mph it will stay around 220* what the hell is wrong now? The stat is about 2 months old, the sensor is brand new, rad cap seems fine, and i dont lose coolant...water pump works alright as well..
Old Mar 21, 2003 | 12:31 AM
MdFormula350's Avatar
sounds like the fan is not coming on...
did you check to see if the fan motor works with 12 volts going directly to it?
Old Mar 21, 2003 | 08:53 AM
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
I have a fan bolted on the water pump so its constantly running...Forgot to mention that...other than that i dont know what the hell is going on...I do have a small exhaust manifold leak, which makes a ticking sound, im not sayin thats the problem but could that air comin out of there make the engine bay that hot?
Old Mar 21, 2003 | 04:31 PM
SilverSub122's Avatar
you didnt mention it but make sure you have an air dam...that thing is like the most important part of cooling other than the fan, i didnt have one for a long time and then put it on and my engine temp dropped about 50*
Old Mar 21, 2003 | 05:00 PM
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
sounds retarded but i have one already...what the hell is causing this overheating grief?
Old Mar 21, 2003 | 08:56 PM
you might try taking out your stat and putting it in hot water and checking to make sure it opens. i bought a new one and it didnt open at all. i always seem to get new parts that dont work
Old Mar 21, 2003 | 09:59 PM
KC10Chief's Avatar
I agree. Buy a good stat, not the cheapest one at Auto Zone. I'd recommend the 180 degree stat. I've bought a defective stat before. If it was fine before you installed the new stat, It's safe to say, you probably got a bad one! Matt
Old Mar 21, 2003 | 11:59 PM
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
that sounds about right to me, i'll go pick one up tomorrow at autozone...any brand recommendations? or just dont get the autozone brand...Im gonna go with the 180 instead this time...keep ya updated on what happens
Old Mar 22, 2003 | 12:53 PM
i bought the best one advance auto had i think it was like 8 bucks and a lifetime warranty..
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
GTAman
Sep 21, 2015 09:57 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
