stock running at 220degrees
Old Mar 25, 2003 | 03:24 PM
Silverblade's Avatar
Old Mar 25, 2003 | 05:24 PM
rezinn's Avatar
What good would that do? So the coolant in your radiator will cool off a bit, it won't cool the engine because the water pump isn't circulating coolant. The one time my fans stayed on as you describe, I came back to a dead battery
Old Mar 25, 2003 | 08:21 PM
heh thanks, i was just making sure i didn't have a problem that would snowball
Old Mar 26, 2003 | 05:09 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Thirdgen fans unless modified go on and off with the key. The heat increase you see only lasts about 10 min or so then the block will start to cool. Some cars will still run the fan when it is off, but it is generally the all aluminum engines where you see it the most.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
camaro71633
Sep 1, 2015 10:24 AM
marcusaw
Aug 10, 2015 08:13 AM
Exxon Limited
Aug 9, 2015 08:13 PM
