heating up after i cut it off
Old Mar 30, 2003 | 11:38 AM
realfast89's Avatar
heres the deal i have a 89 camaro rs with a 350 with a litle work do to it when im sitting at light in gear its stays at 190 when im going done the road its stays at 190 . i have the fan set uo to run all the time . but when i cut it off the temp jumps it to over 200 well over 200 some times to 240 and on a hot day even higher . and its makes my starter lock up till it cools off the longer it sit the hotter it gettes i know its going to go up some but that much what can i do to keep locking up my (new) starter 3rd one .i have the starter wraped in a head shield. im at a lose on what to do i just hate runing to the store going in and having to wait on the car to cool off before i can leave. what can i do email me at realfast89camaro@aol.com or drag1989@aol.com or post here any info you my have
Old Mar 30, 2003 | 11:51 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Like you said it is normal for the temperature to go up (in the engine) after you tur off the car. Mine will go from 160* up to around 190*, and then slowly start coming down. I have no idea why yours is going higher, are you sure the gauge is accurate? Starter heat soak is a somewhat common problem, I'm surprised that the heat shield is not stopping the problem.
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Stryker412
Sep 20, 2015 06:59 PM
bryan623
Sep 19, 2015 10:13 AM
84redta
Sep 19, 2015 09:58 AM
