where are my fan relay's located?
Old Apr 20, 2003 | 06:13 PM
IceBlue91z28's Avatar
Car: 1991 Camaro Z28
Transmission: Built 700r4
I think they are on the firewall near the driverside. There are 3 relays there, all of which look the same to me. Which of the three are my fan relay's if that is where they are? one of the relays has 5 wires in it and the other 2 have 4. please help thanks
Old Apr 20, 2003 | 08:08 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
The two relays that look the same and mounted to the driver side firewall are the relays you want (they both have 4 wires going to them). The Fan relay is the one nearest to the engine and the Fuel Pump relay is the one nearest the driver side fender.
To check to see if you have the right relay just unplg the relay, turn the ignition key to on but don't start the engine and turn the A/C on and the fan should not turn on.
my86bird
Oct 23, 2015 12:20 PM
64goatman
Sep 9, 2015 01:09 PM
Gunsbee
Sep 7, 2015 07:10 PM
85Special
Sep 3, 2015 04:21 PM
tonys91rs
Sep 2, 2015 07:07 PM
