single fan won't come on
Old Apr 25, 2003 | 02:11 PM
blaznbrd's Avatar
Car: 90 T/A GTA
Engine: 350 tpi
I have a 89' firebird and my single fan will not turn on even with the a/c on. Where are the relays located? pics would be greatly appreciated. thank you. Also how can i wire the fan to a switch inside he car so i can turn it on when i need it?
Old Apr 25, 2003 | 07:46 PM
blaznbrd's Avatar
Car: 90 T/A GTA
Engine: 350 tpi
also what does the relay look like. because on my passenger side fender there is nothing on there.
Old Apr 26, 2003 | 10:29 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
The relay has a slight oval shape to the top. Look at the cap side of the radiator behind and down. If there is an oval relay there it should be it. It has a locking tab with a weather seal. Fan switch wiring is available by reading ******* article on the site. Personally me thinks it is a waste of time because the number one reason these cars experience intermittent overheating is because of the relay. Even with a manual switch, you still need the relay. See my point.
Old May 1, 2003 | 01:10 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
on my camaro the relay is on the firewall
Old May 1, 2003 | 07:17 PM
blaznbrd's Avatar
Car: 90 T/A GTA
Engine: 350 tpi
yeah i fixed the problem my fan burned out. So just got a used one from house of camaro it only cost $40.
Bubbajones_ya
Jul 6, 2024 08:32 PM
tommy z-28
Oct 6, 2015 10:58 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
64goatman
Sep 9, 2015 01:09 PM
scottmoyer
Sep 7, 2015 07:06 PM
