heating up when idleing or in heavy traffic
Old May 5, 2003 | 12:54 AM
irocz4life's Avatar
i have an 88 iroc, and ive got a new rad and a fairly new thermostat, and its fine when im driving, but when i sit or am in heavy traffic it heats up really bad to just below the red line, why is it doing this? what can i do to stop this?
Old May 5, 2003 | 03:20 AM
1a12's Avatar
check your fan control. See if the fans are working. If i remember correctly you can unplug the fan from the wiring harness the fan and the fan should stay on when you turn your car on. But i am not sure. The other thing i would check. If the fans work is the Fan control switch. Which turns your fans on when the temp reaches a certain temp.
Old May 5, 2003 | 10:28 PM
SC2camaro's Avatar
Car: 87 BUICK GN
Engine: 3.8 TURBO
Transmission: 200R4
RE cooling
hey guy
change the fan switch located on the pass head in between 6-8 cylinders
part from advance auto is a fs6 it's like 21 bucks
fan kicks on at 219 degrees
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
