Installed NEW H20 pump, radiator, and Hypertech fan switch, temp PEGGED!!!!
Old May 15, 2003 | 10:15 PM
USAF_Maro's Avatar
Today I installed my new aluminum water pump, radiator, AND Hypertech colling fan switch (on at 210 off at 180). And now my temp gauge is pegged and won't go down! What could of happened, or gone wrong? As far as I know everything went OK. Right now I only have 100% water, tomorrow I will drain and put the correct mixture in. Is there anything special I should do with a new cooling system? I drove it about 30 miles with the temp pegged and nothing was smoking or EXTREME heat. The temp gauge went from 100 to 300 (this is the stock gauge) in like 1 second. And when I turn on the car after it is cool, it is stuck there. I think maybe something happened with the temp sender. Where exactly is it located? The fan never came on so my guess is that the temp never made it past 210. Anything from you guys? Thanks
USAF_Maro
Old May 16, 2003 | 01:22 PM
USAF_Maro's Avatar
It seems like as soon as the temp sensor gets water, it pegs....
USAF_Maro
Old May 16, 2003 | 01:41 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Someone on this board said that used to happen to them.... Tap the instrument cluster a few times, it sounds like it is stuck..
Old May 16, 2003 | 05:30 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
usually when the spring in the guage breaks it will peg the needle. If you have WinALDL run that and let us know what it is showing. Most likely it's the guage though.
Old May 16, 2003 | 06:06 PM
USAF_Maro's Avatar
i'M A dumba$$ AGAIN!!!!
I installed the fan switch in the temp gauge sender's place. So now I took it out and put the temp unit back in. And installed the fan switch in the passenger side between the last two cylinders. It won't even get above 18 now WWAAAAHHHHOOOOOO
PS, It was a PAIN IN THE **** to install the fan switch, let me say it again PITA!!!!!!
Whats WinADLD?????????????????thanks
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
krisner89
Carburetors
Sep 20, 2015 08:56 PM
NBrehm
Aug 25, 2015 11:49 PM
TreDeClaw
Aug 14, 2015 06:58 PM
