Testing cooling temp sensor
Old May 18, 2003 | 01:35 PM
kaupca's Avatar
Car: 92 Camaro RS
Car is a 92 camaro with 305 E code engine (single fan). Is there a way to test the cooling temp sensor and if so how? I understand it is a thermistor so should I be able to test it with an ohmmeter? Does the resistance change between the two connections or between them and the ground?. Can I jumper something at the cooolant temp sensor plug to see if the fan comes on? As a side note the fan comes on fine with the a/c.
hydrolic144
Oct 4, 2015 08:23 PM
Papaginos
Sep 27, 2015 03:29 PM
Bstrang6
Sep 8, 2015 04:29 PM
TheExaminer
Aug 26, 2015 04:59 PM
