ram air hood=cooler bay?
Old May 23, 2003 | 08:21 AM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
For those that have the ram air 2 or raptor hoods...if you make them semi functional, to where they bring cool air into the engine bay, have you noticed any cooling differences?
Old May 23, 2003 | 09:47 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
cowl hoods actually work better for bay cooling.
most people actually run warmer coolant temps when they put on a cowl or ramair hood because they forget to block/seal off the area between the top of the radiator and the bottom of the hood up front. If this isn't sealed, then you lose a lot of airflow through the radiator.
TPI camaros don't run into this problem so much because that area is already well sealed in most cases.
Old May 26, 2003 | 10:19 PM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
you wouldnt have a pic of what you described have you? I have the cowl and a open element someone once suggested to seal the hood somewhere so the cowl air goes to the filter... is that what your talking about?
Old May 26, 2003 | 11:21 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Nope,
Engine bay cooling and cool air induction are two different things.
Old May 27, 2003 | 10:18 PM
91Firebirder's Avatar
Car: 91 Firebird
Engine: 305 TBI
Transmission: 5-speed
Axle/Gears: Unk
Does anyone with a ram air 2 hood have a tbi? If so, were you able to make the ram air functionable or did mu jsut do an open filter?
Street Lethal
Apr 30, 2019 12:14 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Aug 24, 2015 06:52 AM
Dialed_In
Aug 20, 2015 01:45 PM
TreDeClaw
Aug 14, 2015 06:58 PM
bryan623
Aug 10, 2015 11:33 AM
