replacing thermostat, having a little trouble
Old Jun 15, 2003 | 05:41 PM
prockbp's Avatar
Car: 1989 IROC-Z
Engine: 1992 TPI 350
Transmission: 1989 T5
Axle/Gears: 1992 10 Bolt Rear w/ 3.42 gearing
ok.. i have a '89 IROC with the LB9... 80k miles
i figured i would replace the thermostat since i'm sure it has never been done before...
but anyway... i'm trying to remove the bolts for the housing, and they won't budge...
i sprayed some penetrating lube on them and let them sit for a while and then came back and got the one on the back side to move a little but it's taking a lot of torque to get it to move... i feel like i'm going to break the bolt off
anybody else ever had this problem? i've replaced stats before on my old z28 and brothers transam without problems
does it sound like the bolts are just frozen into the intake? it might just be time for a new intake if that's the case
thx for the help
Old Jun 15, 2003 | 07:42 PM
T/A gets T&A's Avatar
I say keep using the penetrating oil!
I popped off the head of a bolt in the intake of my '84 Trans Am replacing the stat. I ended up having to drill out a new hole and tap it for a new screw. DEFINATELY not my idea of fun considering the stat replacement shouldn't take that long.
Old Jun 15, 2003 | 08:01 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
Try using "PB Blaster" penetrating spray if you haven't already.
Old Jun 15, 2003 | 08:11 PM
prockbp's Avatar
Car: 1989 IROC-Z
thx for the replies guys.....
i ended up just spraying some more penetrating lube on there and getting out my 2' homemade breaker bar
it worked.. didn't break the bolt... so i guess i don't have an excuse to buy a kickass intake
i cleaned the bolts and holes as good as i could and antisiezed them to death
italiano67
Dec 11, 2016 09:21 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
EFR2000
Aug 18, 2015 08:54 PM
perZ
Aug 15, 2015 01:17 PM
