Hot!!!
Old Jun 20, 2003 | 12:45 PM
1TONYJ's Avatar
Hot!!!
Hello everyone, im nre to this thread.
My questions are: as you can read in my sig. I have a 87 Camaro TPI system in my 1995 YJ. The motor itself runs around 180 degrees. But the Hedman shorty hedders radiate alot of heat. Melting wire wrap as far away from the hedders themself as 6 inches. Could this be from running rich? The fix?
It also will not idle on its own until after i keep it running for a little while. What do you think?
Chad
Old Jun 21, 2003 | 06:20 AM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
more likely running lean, or timing is off
Old Jun 21, 2003 | 07:54 AM
1TONYJ's Avatar
That is what i figured. I did all the leg work putting it in the Jeep and now i have a guy that is going to hook up the ALDL and go over it with a fine tooth comb. Thanks for the opinion.
Chad
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Thaney9
Oct 24, 2015 07:26 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
