fan switch melted
Old Jul 5, 2003 | 01:16 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
fan switch melted
The other day my fan switch overheated and fried out of nowhere. Even now when I jump the wires togather they get hot. What caused the switch to suddenly go? Why are the wires getting so warm? I had this switch in for a while now with noe problems. The only electrical work I did was replace an alternator.
Matt
Old Jul 5, 2003 | 04:00 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
did you have the switch connected directly to the fan, or through a relay?, if it was directly connected, most switches cant handle that big of a load that a electric radiator fan needs
Old Jul 5, 2003 | 06:35 PM
Matto'85TA's Avatar
Directly to the fan. I didn't do the wiring myself. It was done before I bought the car. I was thinking of putting a relay in, but I don't know how I should wire it in. I put in a new 50 amp switch. Hopefully that will hold out some till I figure out what to do. I have a 30 amp fuse inbetween the battery and switch so will that protect the 50 amp switch. Or will this new one probably burn out?
Thanks,
Matt
Old Jul 5, 2003 | 08:20 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
they hooked the fan right to the thermal fan switch , thats not good... You really need to use a high current relay to directly activate teh fan. The FS is only good to around an amp or so.
Old Jul 5, 2003 | 09:42 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
matt, locate the relay that the fan connects to, and im not completely sure(someone correct me if im wrong)
i think it is a green wire, if u ground that then it should turn the fan on
its the F terminal on the relays
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
