couple of ???s
Old Jul 6, 2003 | 06:22 PM
iroc2nv's Avatar
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
couple of ???s
ok guys,
its been said b4 but i havent seen an exact problem to what i have in my iroc...
first the stats...
i have an 87 tpi iroc..a/c removed...all emssions removed..aftermarket headers/k/n filters (not cone)
now...when i am driving at highway speeds...she is fine...its just in stop and go traffic (city) that i have to have the heater on full blast...
i have the fan (yes only one, not lucky enough to get the duel fan setup) on all the time which keeps it somewhat cool...
now is there anything that i can do to keep it cooler without using the heater?? cuz now...the heater doesnt work..(im assuming i blew the heater now, although the heater core is still ok)
2nd...did you find that when you put a cold air intake on your tpi did it make it cooler or not make much of a difference??
thanks guys
iroc2nv
Old Jul 6, 2003 | 08:34 PM
MdFormula350's Avatar
what thermostat are you running? might want to think about using a 180 stat to keep alittle cooler.
the 180 is working great for me, i was running 220 at idle sitting at a local car show for over 10 minutes in pretty humid and warm temps. i had my passengers fan on the whole time with my manual switch.
Old Jul 7, 2003 | 05:26 PM
RPM WOT L 98's Avatar
Depending on how long your fan motor has been hotwired to run all the time, it might have slowed down, and is not really pulling that much air through the rad anymore even though it's spinning, it might not be spinning fast enough to really do much. These do wear out. I replaced my motors bc I suspected this and the new ones blow a lot harder. I can feel the breeze under the car all the way by the rear of the doors. Big difference.
Old Jul 7, 2003 | 05:30 PM
iroc2nv's Avatar
Axle/Gears: 3.45
well..my thermo is like a 180....but its still not working...i havent taken out the a/c rad though... would that make a difference?
iroc2nv
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Linson
Oct 1, 2015 09:50 PM
