I need help in cooling it down
Old Jul 11, 2003 | 01:14 AM
snowman89's Avatar
Car: 1989 IROC-Z Camaro
Engine: 5.8L 355
Transmission: T-5 5-speed
I have a 89 IROC with the 350 TPI in it, well my A/C and pressure fan never came on, so I rigged it so that it owuld come on when the other one did. But I still can't run the A/C with out it getting too hot. It runs about 230-235 most the time when the A/C is off, but like 240-250 when its on. Someone said that they are hot running cars. I was wondering if I could do something else to cool it down.
Old Jul 11, 2003 | 01:17 AM
SLOWTBI's Avatar
do you have a low temp thermostat???
also check out this tech article:
https://www.thirdgen.org/newdesign/tech/cool8dual.pdf
Old Jul 11, 2003 | 02:44 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Well I have a 160 stat and my dual fans are on at all times and I never go above 170 even during the summer!!!
Kevin
Old Jul 11, 2003 | 10:55 AM
SLOWTBI's Avatar
thats what i'm sayin' Kevin. i have a 160* thermostat and a fan switch that come on at 180* (or i can turn it on manually) and my temp is always cool, even with the AC on.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ndndndnd
Sep 28, 2015 08:00 AM
64goatman
Sep 9, 2015 01:09 PM
