Easy cooling fan comparision
Old Jul 15, 2003 | 12:33 AM
Don416's Avatar
I am trying to think of a method for everyone to test there cooling fan without the use of fancy equipment. I was thinking of hanging the cooling fan by one of those fish weight gauges and taking the on weight minus the off weight. I don't know how to convert that to CFM, or if the area has to be figured in either.
Any ideas?
Old Jul 15, 2003 | 05:29 PM
82camaro's Avatar
Car: 82 camaro SC
That won't be accurate. Also, who cares what the fan will flow off the car running free. If you want to do a worth while comparison it needs to be installed in a car and tested under the same conditions.
Old Jul 15, 2003 | 06:32 PM
Don416's Avatar
The reason for doing this, is that all any person can do the same test on whatever brand fan they bought, then compare them on this site, and also compare them to the factory fans. It would be something easy. I myself and read other people trying to feel the air blowing to compare fans, but I couldn't tell a difference.
Old Jul 16, 2003 | 08:10 AM
82camaro's Avatar
Car: 82 camaro SC
The problem is that a fan won't pull as much air when it has a restriction(radiator, condenser, etc...) and the drop in flow won't be the same for all fans.
gta892000
Aug 11, 2019 11:16 AM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
