Putting oil cooler lines back in...
Old Jul 18, 2003 | 09:23 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
will this help in keeping the eng running cooler? And where are the inlet/outlet for it? I got the cooler with the car but am not sure where the lines go to on the rad. Car runs at about 190 to 220, I know that is a normal range but I believe that your system should operate in the fan's operating temp range in anything below 80 deg outside temp. I have the fans coming on at 184, off at 174 with a 160 stat. I still want to go to a dual fan set up but if the oil cooler will get the job done then I'll put it back on.
Old Jul 18, 2003 | 10:24 PM
breathment's Avatar
Attached Thumbnails Putting oil cooler lines back in...-oil_cooler_lines.gif
Old Jul 20, 2003 | 08:55 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Thanks!
Old Jul 21, 2003 | 01:11 AM
25THRSS's Avatar
I thought that was where the factory transmission cooler lines went?
Old Jul 21, 2003 | 07:37 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
I'm so confused! I could swear the diagram above is for the heater hoses. Am i completely out to lunch?
Old Jul 21, 2003 | 12:54 PM
breathment's Avatar
the heater hoses go to the oil cooler. they are all connected kinda.
Old Jul 21, 2003 | 01:32 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Motor oil cooler or tranny oil cooler? I'm still confused. Maybe i better go take a closer look at my car, especially since when the heater core developed a leak it was not replaced and all of the heater vacumn system was left off the car by the previous owner! Does this mean my oil cooler system is not functioning?
Just exactly where is the oil cooler? Internal in rad, or an extenal cooler, and how is it tied together with the heater hose system?
Reddeath210
Oct 6, 2015 08:20 AM
Navy8125
Aug 21, 2015 09:32 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
Leggman1
Aug 6, 2015 04:15 AM
