really need help locating wire for temp guage....
Old Jul 25, 2003 | 11:43 AM
camaro 670087's Avatar
ok so i tried out this single green wire i have floating around my engine compartment and my guage seemed to move up a little. with the car on for about 20 minutes the guage did no reach the point between 220 and 100 whatever temp that is supposed to be. im beggining to think maybe i have the wrong wire and its not sending the correct info? can someone please tell me or show me where this temp guage wire is supposed to be coming from so that i can follow this wire and see if its the right one?
then theres a chance that my car has a really good cooling? but my fans dont even turn on and when i squeeze the upper radiator hose that is feeding the engine with coolant, it isnt even firm or pressurized, i can squeeze it easily as if no coolant is flowing into my engine?
someone please help
Old Jul 25, 2003 | 02:24 PM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Temp sender is located above the plugs between cyl's 1&3 or the fisr 2 from the front on the driver side. It has a single GREEN wire that sort of slides on sideways. Pull off the wire the guage will not come of the low stop, ground the wire it should peg the guage.
Ghettobird52
Jul 5, 2024 11:18 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Dialed_In
Aug 20, 2015 01:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
