new thermostat
Old Aug 4, 2003 | 01:54 PM
Supercharged84Z's Avatar
Car: 1984 Camaro Z28
Engine: 350 CID
Transmission: Beefed up 700R4
new thermostat
hey guys, where is the best place to get a new thermostat? i would like something around 200 deg.
Old Aug 4, 2003 | 07:15 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Jegs or Summitt if you want the high priced ones.
Your local parts store if U just want everyday type.
Old Aug 4, 2003 | 11:47 PM
Engine: 350 CID
they will have different degree settings? i just thought they carried stock temps.
Old Aug 5, 2003 | 07:09 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Yes
Old Aug 5, 2003 | 11:46 PM
bigals87z28's Avatar
Car: Check The Sig
not all of them. If you look at ******* articles, GM has a 170* tstat and lists the part number... i just got mine today (THANKS WILLIE, YOU DA MAN!) and i hope to put it in maybe in a few mins... but sleep is sounding mighty fine right bout now. 200* tstat? why higher then stock? stock is 195*, that can be found at any parts store. Pepboys i belive has a range of them, but im not sure. When i worked for strauss, we had 195 or 180*, and that was for just a specific kinda car.
in an added note, anyone know what size and how many holes to drill around the stat?...thank you.
Old Aug 6, 2003 | 11:09 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
I would drill two holes. Each @ 1/8 inch. I tried 3 holes and on cold nights the engine would not warm up. Even with 2 holes, on a long downgrade, the engine will overcool.
At least that's what mine does.
Old Aug 6, 2003 | 11:13 PM
Engine: 350 CID
got my 180 stat today thanks guys
Old Aug 6, 2003 | 11:24 PM
Car: Check The Sig
i was gunna go with 3 holes, but i hear different stories... i only drive my car in the summer so cold nights arent really a problem.. i might drill 3 holes since i hear from 4 to 2 holes... ill pick the middle. hehehe thanks! now... i just need a gasket and i can put it in... dam GM didnt give me a new one with the stat...
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Stryker412
Sep 20, 2015 06:59 PM
BWilcox
Sep 20, 2015 12:19 PM
