Which gauge should i believe?
Old Aug 20, 2003 | 07:20 PM
firebird frenzy's Avatar
allright i may have found my overheating troubles. My stock gauge will read 240+ while my aftermarket one will read from 190 to 210. the stcok gauge is located about two inches from the exhaust header. while my aftermarket one is on top of my thermostat. which one should i go by?
Old Aug 20, 2003 | 08:05 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I would be more prone to trust the aftermarket guage. My Auto meter guage is more consistent and shows changes quicker. Plus my stock guage will stay very low while cruising, and then at idle it goes much higher...Just my $.02
Old Aug 21, 2003 | 12:59 AM
Badazz86z28's Avatar
Car: 88/Form 86/Z28 87 Trans
Engine: 305 TBI 305 Carb 350 TPI
Transmission: 700r4 x3
Deffinatly trust the aftermarket my stock gauge just kinda floats around (it seems the more right turns i make my engine runs cooler)
Old Aug 24, 2003 | 02:51 PM
MechCD's Avatar
Car: '92 Camaro RS, '93 Ranger
Engine: LO3, Vulcan
Transmission: 700R4, M5OD
Axle/Gears: 2.73, 3.45
Now hold on there.... Isn't the stock sensor mounted on the bottom of the engine inside a drilled hole? On top of the theermostat doesn't exactly sound like a "hot" place to mount a sensor to me. It probably is accurate, but it's not measuring the same point.
Old Aug 24, 2003 | 05:04 PM
Damon's Avatar
The stock gague sensor in a 3rd gen is mounted in the driver's side cylinder head- between exhaust ports 1 and 3. Even if it IS reading correctly, it will typically read 10-15* higher in that location than in the intake water jacket crossover. Beyond that difference, you're usually dealing with gague/sensor inaccuracies.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
