I can't remove my water pump
Old Sep 8, 2003 | 03:35 AM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I'm stuck. I tried to remove my water pump but I'm having a problem, there is 4 bolts holding down the water pump, I took 3 of 'em off except one bolt which is on the driver side toward the bottom, this bolt has hard access to it, it is behind power steering bracket. I tried to loose the belt on power steering but no luck.
any suggestions?????
Old Sep 8, 2003 | 09:32 AM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
Use a short thinwalled socket. I first tried a deep well socket but, it wouldn't fit then I switched to a short craftsman socket and it barely fit. You don't have to loosen the power steering pump and also, don't forget to use some waterpump sealer on that one bolt because it goes through the water jacket.
Old Sep 8, 2003 | 02:04 PM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Thank you for your input
Old Sep 9, 2003 | 11:36 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
It's a tight fit, but you can get a socket in there.
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
MoJoe
Sep 24, 2015 09:12 PM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
