fluid leaking
Old Oct 16, 2003 | 08:51 PM
Firl's Avatar
fluid leaking
My dad called me today and told me about leaking near the firewall/tranny of the car, he checked the hose's and the radiator and what not and none of the hoses seem to be leaking, I was poking around in here and wasn't quite sure what a heater core was and was curious as to if that could be what is causing the leak/problem. Is it possible to just have a hose go from the intake manifold to the waterpump to see if that solves the leak problem and drive without heat, to test the system?
Old Oct 16, 2003 | 10:53 PM
mikes92rs305's Avatar
if it was heater core, ud see a puddle inside the car on the passenger floor. check the weep hole on the waterpump after u drive it...check for moisture
FormulasOnly
Jul 23, 2018 08:47 AM
Mark_ZZ3
May 24, 2018 01:02 PM
jrdturbo
Mar 31, 2016 02:58 PM
HikoriYami
Sep 21, 2015 07:11 PM
Stryker412
Sep 20, 2015 06:59 PM
