i need reassurance
Old Nov 30, 2003 | 11:16 PM
rscamaro305's Avatar
i need reassurance
I checked my coolant about a week ago and it was at an acceptable level. I checked it again today and the overflow botle was empty and my radiator level was about an inch and a half fron the top. I noticed no puddles on the ground, so i just assumed i blew a head gasket. I also tend to think for the worst. Can anyone come up with any other ideas to make me feel better? I was wondering also. I checked my coolant a couple weeks ago with a hydrometer and it was protecting at about -10* F, which is a little low and i do need a flush. Does coolant break down? Could this explain the loss? Any help is greatly appreciated. Thanks a lot. Rock on
Old Dec 1, 2003 | 12:43 AM
MdFormula350's Avatar
not sure if it breaks down or not. being running the same coolant and water mix (50/50) for 2 years almost, being running fine.
umm if no coolant in the oil. then look for the easy checks, water pump weep hole leaking from the bottom of it, bad hose slowly leaks burning off the exhaust before it hits the ground.
check the system when full cold and then look at most of the important parts, then try to look at everything after a normal drive like after u go to the store or something.
solocus
Sep 2, 2015 12:14 PM
I-77 Camaro
Carburetors
Mar 28, 2015 11:01 AM
mcrandrz
Aftermarket Vendor Review
45
Apr 2, 2014 07:21 PM
Kush Barnes
Carburetors
Jul 2, 2013 12:48 PM
BLOWN25TH
Nov 5, 2003 08:49 PM
