Hypertech fan switch #4026
Old Dec 7, 2003 | 02:27 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Ive been gone awhile, had family problems and had to disconnect DSL......anways, im back to finishing my car.....
Im going to get the hypertech fan switch part#4026 which says it turns the secondary fan on between 166-176...is that to cold? or whoudl I go for the other FS 4030 that turns on at 185-200?
If I was to use that switch 4026 what thremostat should I get?
thanks guys
Old Dec 7, 2003 | 03:04 PM
MdFormula350's Avatar
185-200 temp a 180 stat would be good.
i wouldnt go lower with either one also.
166-176 temp a 160 stat buts that pretty cold.
Old Dec 9, 2003 | 06:22 PM
My headers are on there way, I need to get me a fan switch cause the stock one broke, so what you guys recommend?
The Hypertech 185-200 or the colder one? also what about thermostat?
thanks....Im here in NC if that makes a difference..
Old Dec 17, 2003 | 08:35 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I am using the Hypercrap 4026.
It sucks, turns my fan on after about 3 min of operation from cold and then it stays on until I turn off the car. If I start it warm, it never goes off. I am going to get one for a GN. I hear they turn on at about 190-200*.
Old Dec 18, 2003 | 01:00 AM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
I have been using the hypertech switch with the 176 on 166 off for a few years now. I have a 160* thermostat. Everything works as advertised. I guess it being warm enough may have to do with where you live but I have never had trouble having enough heat for the heater.
The only problem i had with the switch is that once i put on my headers the big 'ol connector that they use was too big. I am thinking about relocating it to the driver side.
-Schultzy
Old Dec 25, 2003 | 07:22 PM
Ok, Im going to get the Fan switch on at 200 off at 185.........and the 160 tstat?
GOOD OR NOT?
http://www.thunderracing.com/index.c...ategoryid=1120
Old Dec 27, 2003 | 02:52 PM
toshay away~!...anyone know? or gotta some input?
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
