Automatic Transmision Cooler
Old Dec 11, 2003 | 01:20 PM
mattscamaro's Avatar
I have a '91 Camaro w/ air conditionong. Where could I mount the cooler since I have an air condenser? What's the best kit to get that comes with all the barbed fittings?
Old Dec 11, 2003 | 01:24 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
just put it infront of the AC condensor.
personally i like the B&M super cooler best.
Old Dec 11, 2003 | 03:14 PM
what about the fittings that connect to your original transmission lines? what size does it have to be? does it come with the kit?
Old Dec 11, 2003 | 03:26 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
*shrug*
to be honest, i dont recall what came with what.
i cut the stock line out from the trans on the frame rail near the radiator. did half a bubble flare on it and put a heavy duty hyd hose on it. clamped it. ran it to the cooler, then from the cooler i did the same thing to the other half of the line.
Old Dec 12, 2003 | 12:40 PM
What do I do with the existing holes in the radiator where the transmission lines were? Do I need to seal it up or can I just leave them open?
Old Dec 12, 2003 | 12:42 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
you dont have to. i would any way. just to keep junk out of there.
however, you should use both!
two reasons.
1. most coolers are add ons anyway. plus this way you can dissipate even extreme heat and improve the life of the trans.
2. there IS such a thing as too cold. running the stock cooler after the aftermarket will help to keep the fluid at a reasonable tempature range. even when its in the dead of winter.
Old Dec 12, 2003 | 03:12 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i was under the impression that above 100 degrees is fine. Like the new owner's manuals for chevy trucks say the 4L60e should run between 100 and 250.
although I only run a tranny cooler not through the radiator....this car will never see temps below 60 or so anyways so it won't be a problem for me.
Old Dec 12, 2003 | 03:58 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
im just saying that in winter times, even in the south, running a big air cooled only setup can overcool it.... *shrug*
a temp gauge isnt a bad idea at all for it though.... esp if you arnt using the stock cooling.... why cant you use the stock cooler anyway?
Old Dec 12, 2003 | 05:42 PM
xpndbl3's Avatar
Car: 1984 Z28
i have a thick aluminum radiator that's made for a manual trans car.
Lbibb
May 5, 2016 12:00 AM
jrdturbo
Mar 31, 2016 02:58 PM
loud91rs
Oct 5, 2015 10:05 PM
bjpotter
Oct 4, 2015 07:48 PM
FormulasOnly
Oct 2, 2015 05:52 PM
