couple of questions
Old Dec 28, 2003 | 09:39 PM
Mavrick's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: 5 speed
couple of questions
Ok, my fan just died on me and now my car starts to overheat whenever i'm in traffic, or stopped. Before it broke, the fan always came on as soon as the key was turned, so i'm assuming the motor burned out. Now my questions are, why would the fan always come on? My A/C doesn't work, would that cause it? Also, I was thinking of putting a manual switch in, and i was just wondering whay exactly is the benefits of this? I know it'll let you warm the car up faster, but what about while driving. Is there some sort of benefit to having the fan off when you're driving, say on the freeway? Thanks
Eric
Old Dec 28, 2003 | 10:13 PM
MdFormula350's Avatar
yeah u want it to turn on and off to save life of the motor, i would look into finding the problem.
so u have one fan or two? if so what one is on all the time?
usually when u turn the car the relay gets power and then is being grounded meaning it will turn the fan on.
things to look at:
fan switch connection, between the 6 and 8 cylinders; its a one wire connection and could be burnt up or stuck on.
https://www.thirdgen.org/techbb2/att...postid=1175882
https://www.thirdgen.org/techbb2/att...postid=1080119
Old Dec 28, 2003 | 10:32 PM
Mavrick's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Yea I just have 1 fan. What exactly am i looking for between the 6 and 8 cykinder? I know there is another realy switch over there, i believe for the A/C. how do i check to see if it is burnt or stuck on? Thanks
Old Dec 29, 2003 | 12:00 AM
ok then, well definitely seems to be grounding the relay somehow.
Old Dec 29, 2003 | 12:01 AM
Frozer!!!
Jan 19, 2024 04:55 PM
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
