What should I put on these, if anything?
Old Jan 11, 2004 | 04:29 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Sould I put any kind of sealant or anything on the threads of my coolant switch (drivers side) and my temp switch (passenger side)?
Old Jan 11, 2004 | 05:12 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Usually theres a red substance on a new sensor that seals it off. It's only on the back 3 threads. You could use some teflon tap on the back of the threads as long as there is an area that isnt covered and can make a good ground on the head.
Jake_92RS
Jan 28, 2020 10:37 PM
dyeager535
Aug 28, 2015 08:10 AM
michealleger
Aug 26, 2015 03:29 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
Fronzizzle
Aug 9, 2015 01:15 PM
