Wiring Up Dual Fans...
Old Feb 16, 2004 | 11:51 AM
My86TransAm's Avatar
OK, so I have my IROC fans installed on my 86 T/A. Everything is ready to go, but i have a couple of questions. Im wiring em up so i can turn them on with a couple of switches. I am wondering if i should wire them directly to the battery, and from the battery to two relays, and from the relays to switches. If anybody has an easier way to do this, preferably without cutting into existing wiring on the car. I would print up Willie's fan control paper, but I dont have Adobe Acrobat, and with a 28.8 connection i dont feel like waiting an hour to download it.
Anyway, thanks for all the help!
Old Feb 16, 2004 | 10:59 PM
MdFormula350's Avatar
yeah use relays and just simple flip switches for the ground wires coming off the relay(s)
Old Feb 18, 2004 | 12:16 AM
Ok, so i want to ground the negative ( black) wire coming off the fans, and then the ground thats on the back of the switch is goin to go to the ground on the relay right?
Old Feb 18, 2004 | 11:35 PM
yeah the main wires coming off the fan connectors go right to the body ground.
the grounding relay connections would go to the switch first then the other terminal on the switch would go to a chassis ground somewhere else.
Old Feb 19, 2004 | 12:18 AM
Ok, i just want to make sure i get this right...
Ok, so i have 3 terminals on the back of my switch.
the top one is a ground
the middle one is a power
the bottom one is also a power, but i think that its for the led on the switch
so on the top one i want it goin to the ground on the relay, right?
and on the middle one i need the power from the relay?
and on the bottom one i need what?
Sorry to keep askin the same questions but im not too good with electrical stuff, and i wanna make sure i get this done right
Old Feb 20, 2004 | 10:38 AM
well unless u want to hook the led up i only think u need the ground one.
if u have a simple toggle switch u wouldnt need any power going to the switch.
just the switch inline on the ground wire coming from off the relay it would be fine.
Old Feb 21, 2004 | 02:11 AM
Well i got it done last night. I got to looking at the diagram on the back of the toggle switch box and the way its setup it will only work if there is power goin to the LED terminal. So i just got a male end connector and spliced the two wires into one and ran it to the empty ignition slot in my fuse box. works pretty slick, even if i leave the fans on, they'll turn off as soon as the ignition goes off. anyway, thanks for the help, probably wouldnt have got it done!:hail:
Old Feb 21, 2004 | 02:13 AM
blah, double post
Old Feb 21, 2004 | 02:28 PM
glad u got it.
Old Mar 16, 2004 | 05:16 PM
Ville H. Valo's Avatar
Car: 1992 Camaro Z28
Engine: 5.0 Liter (305)
My86TransAm, CAn you tell me how to wire it with an LED switch?
Old Mar 21, 2004 | 06:32 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
i hope you fuse you switches.
when you say run led, you mean like when the power is on an led comes on? just wire it up to the on side of the switch and then ground it out
Old Mar 22, 2004 | 08:00 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
What exactley is a relay for. I just have a switch in between the hot that runs to the fuse panel and the fan.
Brinkkl2000
Aug 4, 2018 08:29 AM
onefreakz
May 14, 2018 12:15 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
