extra hole on edelbrock water pump?
Old Feb 27, 2004 | 06:57 PM
irocz_ca's Avatar
just bought edelbrock victor series water pump for '89 irocz 5 liter tpi. when i got the old stock one off and about to put the edelbrock, i noticed that there is an extra hole about 3/4 inch diameter. what is that hole for? the old one didn't have it. can i just plug it with a bolt? will wait for any reply before putting it on. thank you for info.
Old Feb 27, 2004 | 11:20 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
if it's on the top part of the water pump, it's for carb'd cars as a return for the heater hose, just cap it off and go about your business.
Old Feb 29, 2004 | 03:53 AM
25THRSS's Avatar
Edelbrock makes a direct fit one for your car. I'de send it back and get the right one.
Old Mar 1, 2004 | 01:31 AM
breathment's Avatar
and don't be suprised if the only difference is one they send you has a plug in that spot
Old Mar 1, 2004 | 12:43 PM
25THRSS's Avatar
no, it has no hole at all.
Old Mar 2, 2004 | 10:47 PM
breathment's Avatar
haha im just used to people coming in to work with the water pump i just gave them saying its different then the original. and so i pull out a wrench and 45 seconds later problem solved. this is with OE parts though
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
87iroctheo
Wheels and Tires
Sep 2, 2015 03:29 AM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
