Weird Problem?
Old Feb 28, 2004 | 11:31 PM
RadarRunner's Avatar
Car: 1987 Z28
Engine: LG-4 305
Transmission: 5-speed
Weird Problem?
My 87 Z28 has had all of the expected cooling problems over the years. A few weeks ago I swapped the carb, dist, & intake manifold out & went non-computer. While at it I put in a new radiator & thermostat either 160 or 170.
Now it seemed to never want to warm up going by the temp guage although it had plenty of warm air etc.
I went ahead & swapped out the thermostat as I had a small leak on the housing & couldn't get it to seal. Went with a 180 stat this time & the car finally does warm up going by the temp guage, although it doesn have warm air quickly.
Problem is when I hit the highway it immediately drops way down like it is cold. Could it be a bad stat which would have meant the first one was bad too. Don't recall the brand but went with a better one than the el cheapo route.
Could it be a bad tempt guage?
Old Mar 1, 2004 | 01:13 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
It wont warm up because you went with a cooler stat. Try going back to the stock 195 and see if that fixes it.
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
