ok big problem.....searched and didnt find much
Old Mar 14, 2004 | 12:45 AM
FireRed91Z28's Avatar
Car: 91 Z28
Engine: currently 350...BUILT 383 soon
Transmission: T56 w/4.10's
91 z28 350
car overheated very badly tonight as i was letting my lady friend do donuts n stuff and when she stopped i could have cried. i saw steam pouring out from under my hood, opened it and my radiator cap was shootin steam out the pressure release hole. once this stopped there was a puddle of coolant under my car and i didnt have any way of seeing where it was coming from with a low car in the dark. i let the car sit for bout an hour 1/2 and turned it on, it must have been cooled down cause my heat wasn warn yet but my temp guage would now read higher and higher the more i step on the gas. it was pinned all the way on my ride home and would only go down when i released the gas.
im tired as hell so i cant check anything not to mention its freezing out. so im hoping im just now low on coolant but where did this puddle of coolant come from? what should i check out to see if anything blew? and why is my temp guage all messed up?
Old Mar 14, 2004 | 09:21 AM
Lonestar's Avatar
Car: 1985 Firebird
Engine: 327
Transmission: TH350
Steam turns to liquid after it cools, so the puddle may be from a defective cap. I would replace the cap, refill the system, start the car and check for leaks. Watch your temp and go from there.
Old Mar 14, 2004 | 02:31 PM
MdFormula350's Avatar
could be as simple as the radiator cap. but definitelty was overheating which is pretty bad, could be the t-stat stayed closed also.
I would do what Lonestar said in the day time and see whats going on.
Old Mar 14, 2004 | 07:15 PM
Car: 91 Z28
alright i checked it out and it took an entire bottle of coolant to fill my radiator which solved my temp guage problem and i havnt drivn much today to see if it stays at my normal opp temp and not rise. let the car warm up with the cap off to make sure there was no air bubbles and then put cap back on. im not sure if my cap is defective now but for the time being it doesnt seem to be leaking any more.
thanks for the help
one other thing, i remember reading on a post about a total fan control system where with the flip of 2 switches i can turn on both fans manually and with the flip of a 3rd switch i can bring back the computer to control my fans like stock. does anyone remember this post?can they send me a link.
Old Mar 14, 2004 | 10:38 PM
https://www.thirdgen.org/techbb2/sho...hreadid=170903
Old Mar 15, 2004 | 07:19 PM
Car: 91 Z28
yup, thats it. thanks a lot
Old Mar 16, 2004 | 08:29 AM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
If you've boiled it over then you should flush the system fully asap or you'll get sediment cloggin your system.
Si. :lala:
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
sreZ28
Aug 14, 2015 07:48 PM
