Annoying Leak, Need Help FAST!
Old Mar 19, 2004 | 08:16 PM
Syxx613's Avatar
Car: 1987 Trans Am GTA
Transmission: 700 R-4
i dont know what to do now, im at my witts ends here. i just replaced my radiator thinking i had a radiator leak and its still giving me that stupid little drip drop. its coming from the passanger side as far as i can see. are there any lines i should be looking for besides the radiator hoses? i already replaced the lower one. i really need help here im about ready to trash my GTA.
Old Mar 20, 2004 | 05:29 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
There are a whole bunch of small lines that run to and from the radiator. Well, not a whole bunch, probably about 4 or 5, and they're all on the passenger side. Take your time and check those. Check your water pump, too. If it is bad it will "weep" from the bottom. Don't trash your GTA!
Old Mar 21, 2004 | 01:04 AM
onebinky's Avatar
Intake manifold gasket, head gasket, freeze plugs, water temp switch, heater core, heater core lines, heater valve, warped head or block. Does it burn white smoke? Like the other guy said, if the water pump gets worn it'll start to leak thru the weep hole.
Old Mar 21, 2004 | 09:30 AM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
this will 99% of the time drip from the lower radiator hose.......on the pass side
Old Mar 21, 2004 | 06:20 PM
Syxx613's Avatar
ok thanks for the tips. it doesnt blow white smoke when i run it so it shouldnt be a warped head. i was thinkin cracked block as a worst case senario but then i thought... would the engine even run if it was cracked? i just had a HUGE leak yesterday drivin to the beach. car temp guage said 260 degrees. i made it home but the car SEEMED to drive fine but i still tried to get home in a hurry. it was just pouring out yesterday so i think a hose might have blown or something? ill check these things, thanks.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GTAman
Jul 3, 2024 07:29 PM
customblackbird
Oct 1, 2015 04:30 PM
timonator
Sep 30, 2015 12:52 PM
bubbaz28
Sep 18, 2015 02:09 PM
