too hot
Old Mar 21, 2004 | 09:45 PM
b82ta's Avatar
Car: 1982 Firebird Trans Am
too hot
i recently swapped a 350 into my 82 trans am. but i cant run for more than 5 min before it hits 230 and i shut it off. why is it running hot? i know that the radiator is good cause i had it tested and car came from the factory with a 305. i also have an aluminum flex fan and the car leaks a little coolant from somewhere by the water pump. is the leak related to my cooling problem it doesnt leak much at all, just a little puddle after you let it sit over night. what are some of the things that could be causing my problem?
Old Mar 21, 2004 | 09:49 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i'd flush out the entire cooling system and buy yourself a new water pump if it's leaking, you can get a HD water pump off a caprice cop car when you buy one. it'll have better bearings in it.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Thaney9
Oct 24, 2015 07:26 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
