heater coolant shutoff valve?
Old Mar 31, 2004 | 07:34 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
anybody do this mod? anybody know about this mod? i burn up every summer 'cause the heat just pours out of the heater (my a/c doesn't work) core. i've heard this mod is the cure, but i need to know how-to-do.!!! thanks
Old Apr 2, 2004 | 11:45 PM
TPIgirl's Avatar
Car: 89 Irocz
Engine: 350TPI $6E
My friend has one on his truck. Get a brass ball-valve and add a barb-ended brass fitting to each side so you can put it inline on your heater hose. You install this valve on the hose coming from your intake and going to the core, not the return line back to the radiator, though either will stop the coolant flow. I know it does work.
Old Apr 3, 2004 | 07:58 AM
wdigitog's Avatar
thanks tpi girl...your site looks cool..anyway you can draw a diagram of the hook-up? where do you find a valve like the one you described?
Old Apr 3, 2004 | 01:50 PM
TPIgirl's Avatar
Car: 89 Irocz
Engine: 350TPI $6E
you don't really need a diagram. You just cut the hose a few inches from the firewall and put the valve inline on that hose. The valves and fittings are sold at a local hardware store here.
Old Apr 3, 2004 | 02:28 PM
TPIgirl's Avatar
Car: 89 Irocz
Engine: 350TPI $6E
Here is a picture from my friend's truck. The valve is inline on the return hose from the core. His returns back to the waterpump, but I think all TPI cars have the return straight back to the radiator just below the fill cap.
Old Apr 3, 2004 | 06:24 PM
wdigitog's Avatar
thanks for the pic! i thought you had to have the coolant return back to the block? i quess the heater supply loop is it's own circuit? all we have to do is cut the one side off?and it doesn't cut off the flow to the rest of the engine? thanks for the info...guess i'll have a much cooler summer than last year!!
Old Apr 3, 2004 | 11:03 PM
TPIgirl's Avatar
Car: 89 Irocz
Engine: 350TPI $6E
The heater is it's own circuit. Hot coolant coming from the heads goes up into the intake manifold and is then routed via heater hose to the core behind the firewall. The return line from the core will either go to the input side of the waterpump, or directly back to the radiator on the passenger side like TPI cars do.
You could simply loop the hoses to bypass the core but the valve is more convenient to turn on and off.
Old Apr 4, 2004 | 08:46 AM
wdigitog's Avatar
you're the best TPI girl!! i am now filled with your knowledge and wisdom!! how long have you been with the forum? how long have you owned your third gen? you seem very hip with the rest of those gearheads!!
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
89 formula TPI
Oct 6, 2015 08:40 PM
355tpipickup
Sep 13, 2015 11:35 PM
FormulasOnly
Sep 10, 2015 09:07 PM
