Radiator Cap
Old Apr 7, 2004 | 08:22 PM
Hal3246's Avatar
Car: 1986 P. Firebird T/A
Engine: Stock v8 305 TPI
Axle/Gears: N/A
Radiator Cap
I went to get my water pump done at a garage and the machanic changed the radiater cap as well, originally on it was a 15 lb psi cap and it put on a new 7 lb psi cap, is there anything wrong with this?
Old Apr 8, 2004 | 02:25 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
As long as your not boiling coolant out the cap your alright. Lowering the cap pressure will lower the temp that your coolant will boil at. Its about 2 degrees for every psi you lower it.
Old Apr 8, 2004 | 04:45 PM
Hal3246's Avatar
Axle/Gears: N/A
oh alright thanks, I didn't know
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
Stryker412
Sep 20, 2015 06:59 PM
84redta
Sep 19, 2015 09:58 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
