fan not working
Old Apr 22, 2004 | 09:44 PM
jay92,85,79's Avatar
Car: 85z28,
fan not working
Hey all i have a 92 camaro that is over heating.The fan works.But not getting power to it.I found the relay for the fan and put hot wire from the battery and it kicked on.So I know the wiring is fine from relay to the fan.i all so tried pluging that wire harness into the other relays still did not work.So wht should i do next.Cooling temp senor?Someone told me the thermostat but i did not think that had anything to do with the fan turning off and on.Its going above 220.Thnks for the help.
Old Apr 23, 2004 | 09:34 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Its not the thermostat, thats for sure. What do are fan switchs kick on at again, I cannot recall, I think it may be higher than 220. What I would so is ground the fan switch wire, and see if that turns it on, if it does your fan switch is bad, if it doesn't its probably a wireing problem somewhere.
Old Apr 23, 2004 | 06:29 PM
Conv90RS's Avatar
Watching to see how this one turns out
Old Apr 23, 2004 | 08:10 PM
Car: 85z28,
well i put a new sensor today and thermastat tried a relay nothing.But if i put a hotwire on the wire that plugs into the relay the fan kicks on.So i know its from the relay back.about to just wire it up to a toggle switch.
Old Apr 23, 2004 | 08:13 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Don't we have a 235 fan switch?
Old Apr 23, 2004 | 08:15 PM
Car: 85z28,
ahhhh i don't know whats that.Not that good with elec. stuff.Ask me about bodywork i can help
Old Apr 23, 2004 | 08:16 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
235=the temp the fan switch turns on at.
Old Apr 23, 2004 | 08:19 PM
Car: 85z28,
o ok at timesif i'm in alot of traffic it goes way above that all most up to 260 than right when i start moving cools down but with summer comming up thats not going to work
Old May 7, 2004 | 03:26 AM
Conv90RS's Avatar
Update? Have you gotten it fixed? Can I ask a dumb question? Where is the fan switch on a 90 Rs Conv.?
Old May 7, 2004 | 07:46 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
In the passenger side head above the starter, you need to get it from the bottom.
Old May 25, 2004 | 07:48 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
Transmission: 700-R4
I am kind having the same problem but i just fixed it,i just don't know if the fan is supost to kick on when i turn the ac on.The fan works fine by itself but if i turn the ac on nothing happens.Any ideas?
If your car is like mine the fan turns on at 235 thats why i am getting a fan switch from jegs that works at 180 and off at 195.About the fan relay you will have for wires coming to it.RED,BLK/RED,GRN/WHT,TAN.With the ignition on check for power on the red and the other black and red,if you have power on those maybe your problem is other.....
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
