Overheat, now rough idle
Old May 2, 2004 | 06:34 PM
87Formula356's Avatar
Car: 87 Formula Firebird
Engine: 5.8Ltr 356
Transmission: WC t-5...... probobly go boom soon.
Bad day, i was in the lincoln tunnel when my cooling fans stopped working, terribly traffic, it was on my way out of the New York Auto show, i had no where to pull over, and no chance to let the car cool, the car overheated pretty bad till i finally got out of the and shot to the first place to pull over which turned out to be a gas station. all is fine now, but it's been a few weeks and my car has idled rough (jumping by 300-400 rpms) ever since the over heat and was rock steady before. Does this mean iv'e damaged something terribly ? or is there a chance i just caused some type of ecectrical problem with the tps or iac motor? It's a 350 tpi, does anyone know a procedure to check the components that may be causing this?
Old Dec 19, 2011 | 10:24 AM
tyrant609's Avatar
Car: 1987 Trans Am
Engine: 5.7 350 TPI
Re: Overheat, now rough idle
Dont mean to bring this back from the dead, but i am not having this same problem. Went away on a trip didnt check fluid levels when i got back. Realized my car was overheating. Car starts fine no smoke coming out of exhaust but rough idle and loss of power like a missfire. No cloudiness to the oil so I think the head gasket is fine. Could i have messed up my plugs or some sensor like the IAC? Any help would be great thanks.
Old Dec 24, 2011 | 04:46 PM
amlv20's Avatar
Car: 1986 iroc-z
Engine: 5.0 tpi
Axle/Gears: stock.
does it still over heat? have you checked the spark plugs? it could be an injector issue.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
