my fan has a mind of its own.
Old May 20, 2004 | 07:21 PM
fbodyandy's Avatar
I have a 91rs tbi 5speed. and the fan is nuts. i have replaced the temp switch. and the fan motor. this is what it dose, if the car gets over the (222* i think) temp it turns the fan on. then the damn thing never goes of even when i turn off the car pull the key and walk away. the fan will run till it uses all the batts. juice. any ideas???
Old May 20, 2004 | 07:28 PM
ChaosRanger's Avatar
Car: 1984 F41 T-Top
Transmission: 5 speed
check the fan relay?
The relay is on the drivers side inbetween the fender and the brake on the firewall. I don't have a tpi/tbi setup, but a pic I have shows that the relay is in the center of the three relays.
Old May 20, 2004 | 08:43 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
YEP,the relay is probably sticking.You may be able to clean the contact points & spray some brake cleaner on it.That might make it work again.If not replace it maybe.
sheachopper
Jul 31, 2019 11:27 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Fanatic1074
Oct 2, 2015 03:47 PM
FormulaEngland
Sep 30, 2015 01:50 PM
