relay question
Old Jun 3, 2004 | 06:19 PM
bp91z28's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t700r4
relay question
can anybody tell me what readings i should see on the primary fan relay pins. I have a dual fan setup. i looking at my reading of 12v on D and F. that dont make sense to me. thanks
Bryce
Old Jun 3, 2004 | 08:03 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
that a dual fan car?
if so,with the relay unplugged, the ecm has 12v on the trigger wire(f) until it wants the fan on, then it grounds the wire
D is 12v key on only
you should also have 12v at pin E
pin A goes to the fan(should have a resistance to ground with the relay off)
secondary fan is different, if the relay is unplugged, F will not be ground or 12v, it will read 12v with the relay plugged in
RazorN8
Jan 7, 2022 11:44 AM
Caspar
Jun 19, 2016 11:19 PM
Bert87
Aug 23, 2015 03:50 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
