Camaro Newbie needing Cooling help
Old Jun 29, 2004 | 07:26 PM
ttop25's Avatar
Car: 92 25th RS
Hello All,
I have a 92 Camaro RS 5.0 TBI.
I am wanting to replace the Cooling Fan switch with a newer Jegs low temp turn on. Also, would like to install a new Thermostat 180 deg.
How do I properly dump all of the coolant?
Is there a plug somewhere that I can unscrew and drain?
Where is the coolant temp sensor switch located?
Any help would be appreciated.
thanks,
ttop25
Old Jun 30, 2004 | 10:22 AM
Chevyz2882's Avatar
Car: 1982 Z28
Transmission: 700-R4
You radiator plug should be on the passenger side of the car at the bottem of the radiator
Old Jun 30, 2004 | 12:57 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
if drain plug is frozen just remove lower hose and jump out of the way--it'll all come out!
Old Jun 30, 2004 | 11:54 PM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
http://www.madvet.com/shop?frame=3.138.944
The coolant fan switch is located on the passenger side head. Drain the coolant the way everyone else said, except it the drain screw is frozen up, I usually use an extension to smack it loose.
I believe the size is 21mm (or 13/16") to remove the switch.
There are also other options instead of buying the Jeg's switch.
Let me find the thread....can't find it.
But I did copy the info. This is a list of part numbers of other factory type switches, I think it was from Autozone (or one of those places)
FS6 - Closes at 204*-220* F- Retail $21.59
FS4 - Closes at 211*-227* F- Retail $8.69
FS1 - Closes at 222*-238* F- Retail $9.49
FS3 - Closes at 240*-252* F- Who would buy this one??
You will also want a lower temp thermostat. I run a 180º with a few small holes drilled in it.
IROCZ1989
Jan 24, 2016 03:55 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
Leggman1
Aug 6, 2015 04:15 AM
