Condensator fan vs dual cooling fans?
Old Jun 30, 2004 | 05:42 PM
virole's Avatar
Car: 1986 Firebird Trans Am
Engine: Lg4
Transmission: 5 speed
Ok. My car will not overheat, even when the temp here in south florida has reached over 90 already. The problem is when I use the AC. In stop and go traffic with the AC on, not only the car will overheat but the Ac wont blow cold air. At normal speeds (over 45) the car will stay at 180 degrees and the ac will work almost perfect. It is obvious I need more air flow trough the condenser and radiator during heavy traffic (75% of the time). I will like to know from your expers out there if I could overcome this by just installing a condenser fan (like those on modern cars) or if a dual aftermarket cooling fan will do it.
Your help will be apreciated
My car is a stock 305 carburated
3 core copper radiator
160 thermostat
new air dam
single electric fan (factory):
5 speed
Old Jun 30, 2004 | 11:36 PM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
I bet if you just upgrade to a fan that pulls in more CFM of air, you'll fix your problem
Check out Summit and Jeg's for prices on aftermarket fans.
codeysabatini
Nov 10, 2015 04:07 PM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
