Aftermarket or stock replacement radiator?
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
i'd recommend stock unless you're really hardcore about spending lots of money and making it run all of 10* cooler.
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
Check out Captn Picard's post about putting in a Griffin aluminum rad. Lots of pics and the costs there. The rad is about 190.00.
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Here's the link. https://www.thirdgen.org/techbb2/sho...hreadid=247826
I paid 179.99 from Summit for an aluminum Griffin. A stock rad costs the same or more. Which one would you pick?
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
every one with the griffen, any one have troubles with the wonder bar and the radiator?
my radiator is leaking slowly, it has the plastic end caps and a aluminum core, that not stock is it? but the core seperated ever so slightly from the end plate. pain in butt!
from what i have gathered from other posts all have have to do is mod the rubber mounts, and make sure it clears the ps and ac hoses, i know i can do this, but if it hits things like the wonder bar then ill pass.
i have the mechanical fan shroud and it is all one piece with the rad mount, is it the same deal where it just fits "tight"
1992 Trans Am
May 10, 2023 07:19 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
