Radiator and Fans Installed
Old Jul 17, 2004 | 06:51 PM
Max_Maro92's Avatar
Car: Purple Haze Metallic 92RS
Engine: Super-ram 383cid
Transmission: race prep 700R4
Hello,
Well I am in the process of updating my Camaro...again...for the fourth time...and I figured I would put up a pic of todays progress. I installed a Griffin radiator and Flex-A-Lite dual fans. I know there has been some concern of the fit of the griffin radiator. I have the big griffin with the dual 1-1/4" rows. It does fit without any cutting...but it's really really tight. So Tight in fact that I'm more than likely going to have to install the lower radiator hose before the radiator goes into the car. Note my car does have AC, I had to remove the factory rubber mounts and use thin rubber strips...but I'm fairly pleased with the results. Anyway I just finished working on it for the day...feel free to post any comments or questions.
-Mike
Old Jul 17, 2004 | 09:15 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Looks nice!!
You bought the entire kit right? I like the way they designed the upper support. Clean install. Of course the lack of an engine could be throwing me off.... lol
Old Jul 17, 2004 | 09:34 PM
Max_Maro92's Avatar
Thanks for the compliment!
What you see in the pic is not a kit though. I bought the radiator and fans seperatley and made my own radiator retention/fan mount bracket.
I hope to have an engine filling up that space very soon!
-Mike
Old Jul 17, 2004 | 11:59 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
-Mike
That setup looks kick azz...Could you tell me how you made the brackets? Do you have specs? I also would like to switch my single fan to duals. What size are they? Part numbers? And, how did you hook the fans to the rad?
Old Jul 18, 2004 | 12:03 AM
Max_Maro92's Avatar
Thanks for the great reply!
It's a bit late in the evening tonight but tomorrow I will get some better photos of the individual pieces and write up how to do it. It's very simple, just takes a little attention to detail. The materials are readily available too. Again thanks for the compliment.
-Mike
Old Jul 18, 2004 | 01:10 AM
-Mike
*drools in anticipation* Your welcome...
Old Jul 21, 2004 | 12:30 AM
-Mike
Any progress on the write up and pics? I am really interested in knowing.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Aug 22, 2015 06:52 PM
