fail safe switch?
Old Aug 11, 2004 | 06:28 AM
SNET Telly's Avatar
Car: 92 1LE B4C
fail safe switch?
Is the fan pressure switch the one on the pass. side head? If so where is the fail safe switch located at?
Old Aug 11, 2004 | 05:55 PM
0103837's Avatar
Car: Camaro
Engine: Gas
Transmission: Automatic
Pressure swich??? It is a temperature swich, and the one that controls the fan is on the pass. side head. And the fail safe... If no work then no work... At least I dont have any fail safe swich...
Old Aug 11, 2004 | 11:15 PM
SNET Telly's Avatar
Car: 92 1LE B4C
Yeh I mint Temp. not pressure. I was told there was a fail safe switch from a post in the DIY Prom. Wasn't sure if it was a diffrent switch on some cars, or maybe built into on of the other two temp sensors. It's always better to ask I deffently dont' know everthing.
Old Aug 12, 2004 | 06:22 PM
0103837's Avatar
Car: Camaro
Engine: Gas
Yes, it is better to ask. I usually just try things with out asking and that usually means that I have to do it at least 5 times, and after that I have to ask someone who knows how its done
Old Aug 12, 2004 | 08:18 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
It varies, depending on exactly what car you're talking about. A look at the wiring diagram for the specific year & engine might help to avoid confusion.
In the case of your '92 B4C, you should have dual fans. The primary fan is ECM controlled, and the secondary fan is activated by the temp switch, or by an A/C pressure switch. I suppose you could consider that as "fail safe" in that the secondary will still function even if the ECM takes a dump. (IMHO, to be truely considered fail safe, there'd have to be a backup system on the primary fan as well)
With other years & models of thirdgens, it varies. Some have no provision at all for ECM control over the fans. IOW, there is no backup system.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
tglennon11
Sep 23, 2015 05:30 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
FormulasOnly
Sep 10, 2015 09:07 PM
Randomtask2
Sep 10, 2015 08:37 AM
