air dam
Old Aug 13, 2004 | 05:53 AM
dmp7777777's Avatar
Car: 1982 z28
Transmission: th350
air dam
im here to tell you that the air dam is a must if you aint got one get one, itll solve the problem.i was running 210 220 now its like 180 190 all day long, thankx fellas
Old Aug 15, 2004 | 12:42 AM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
Transmission: Wishin Manual
What do you mean air dam? and where in iowa are you from?
Old Aug 15, 2004 | 07:07 AM
dmp7777777's Avatar
Car: 1982 z28
Transmission: th350
the air dam is underneith the front end of the car and it forces the air into the rad,without it the air just blows right on pass everything
Old Aug 15, 2004 | 12:31 PM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
Ahh yes. that thing, mine hangs a little off, dont know why though.
Old Aug 15, 2004 | 01:34 PM
dmp7777777's Avatar
Car: 1982 z28
Transmission: th350
maybe missin some bolts or might be broke i had to get mine from the dealer because it such a hot item. you loose um on parking and s***
Old Aug 27, 2004 | 01:00 AM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Without the airdam to break up the airflow, it creates a suction in the engine compartment, thereby removing any additional airflow due to the low design of the 3rdgens.
Old Aug 31, 2004 | 07:04 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
I just ordered mine, and it should do the magic. My car will heat up when I am driving in speed. However, a new "heavy duty" water pump really droped my temp down quite a bit. So, you might want to look into that as well.
Good luck.
Bubbajones_ya
Jul 6, 2024 08:32 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
tommy z-28
Oct 6, 2015 10:58 PM
edoff13
Sep 11, 2015 03:55 AM
scotrans am
Sep 5, 2015 04:26 AM
