running too cool w/ 180 t-stat
Old Oct 14, 2004 | 10:02 AM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
ever since I removed the ac, smog and put in headers, my car never gets past the first tick mark on the gauge when the car is in motion. I had a 180 t-state w/ 2 holes drilled init and it ran way too cold. now I have a 180 w/ no holes and it runs about the same (right at or before the 1st tick) does this mean i have a faulty t-stat? is it possible to run that cool w/ a properly operating 180 stat?
Old Oct 14, 2004 | 01:41 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
I just installed a 180 stat as well. I'm right there with you at the first hash. It will heat up some sitting in tragffic, but just cruising it pretty much stays right there at the first tick.
Your guage may be a little off, and mine too, but I wouldn't be too concerned. Even though that first tick is one-half way between 100* and 220*, it does not represent 160*. Its hotter but I don't know what temperature it represents.
But, how could you be running any cooler than your t-stat temp anyway? I guess you could if it was stuck open, but I doubt its faulty since we are having such similar results.
That first tick is probably close to 180 degrees. It freaks me out some too because I;ve been running 195* stats and have never run this cool. I love it.
Old Oct 16, 2004 | 12:11 PM
92GTA's Avatar
Hook into your ecm and you will find that the first mark is 180-185. I also have a 180* thermostat...
Old Oct 17, 2004 | 05:07 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
i dunno if its too cool or not but im like the same as you are but im right on the first tick i was sittin in a parking lot waiting for somone for 15mins with the car on and it never really rose from that first tick much only a tiny bit but not much. i want to run warmer and will when i switch back to antifreeze from water wetter and water
Old Oct 17, 2004 | 09:51 PM
92GTA's Avatar
I'm using Prestone pre-mix antifreeze/coolant...
Bubbajones_ya
Jul 6, 2024 08:32 PM
randy210
Oct 15, 2015 03:43 PM
tommy z-28
Oct 6, 2015 10:58 PM
Stryker412
Sep 20, 2015 06:59 PM
BWilcox
Sep 20, 2015 12:19 PM
